[官方发布] 公布2017远东论坛学术报告报名(第一批:第1-第30场)
查看8060 | 回复0 | 2017-3-16 11:11:39 | 显示全部楼层 |阅读模式
“2017远东无损检测新技术论坛”学术报告报名公告
(第一批:第1场至第30场)
自即日起分批公布已收到的2017远东无损检测新技术论坛学术报告报名,现将第一批1-30场学术报告的题目、报告人和所代表单位公布如下:
1、报告题目:工业数字射线检测的发展趋势——从纳米尺度到宏观(大会报告)
Title of the report:Current Trends in Digital Industrial Radiography -From Nano to Macro Scale-(Plenary Lecture)
报告人:乌韦伊维特博士
Reporter:Dr. Uwe Ewert
单位:德国材料研究院
Unit:BAM
摘要Abstract:
Similar to the successstory of digital photography a major upheaval has been observed in digitalindustrial radiology. Digital Detector Arrays enable an extraordinary increaseof contrast sensitivity in comparison to film radiography. Computed radiography(CR) with phosphor imaging plates replaces film applications. New concepts forComputed Tomography (CT) application paved the way for implementing of CT unitsin industrial serial part inspection for flaw detection and dimensionalmeasurements.
Keywords: Digital radiography, computed tomography, laminography, dimensionalmeasurements
2、报告题目:电磁相机——第四代ECT的开端(大会报告)
Title of the report:Magnetic Camera, the Beginning of 4th Generation ECT(Plenary Lecture)
报告人:李金逸博士
Reporter:Prof. Dr. Jinyi Lee
单位:韩国朝鲜大学
Unit:ChosunUniversity, Korea
3、报告题目:德国核电站老化管理系统(核电专场)
Title of the report:Ageing Management System for German Nuclear Power Plants(Special Nuclear Power)
报告人:安东艾哈德博士
Reporter:Dr. Anton Erhard
单位:德国无损检测协会
Unit:German Society for Non-Destructive Testing (DGZfP)
摘要Abstract:
The German Reactor SafetyCommission (RSK) considers that a systematic ageing management for nuclearpower plants is necessary, against the backdrop of the decision of the GermanGovernment in September 2010 about the life time extension of the Germannuclear power plants. This decission was made a few months before the Fukushimaaccident. According to the Fukushima accident, this decision was annulated andthe the phase-out of nuclear power for Germany was decided. Independent on thisdifficult decision for the German nuclear industry, the establishment of asafety standard for ageing management system was continued.
The presentation isfocused on the ageing of mechanical components and the requirements for thesecomponents described in the KTA 1403 safety standard. KTA is the German NuclearSafety Standards Commission which is responsible for the safety standards. Duethe fact that the ageing management is close related to the materialdegradation and thus on the integrity of the components, also modernnon-destructive testing techniques (NDT) must be available for the inspectionof these components. Therefore, some of possible NDT methods are presented inthe present contribution. The NDT methods are selected under the considerationof leak before break criteria on axial defects in pipes. Regarding thesedifferent needed interdisciplinary faculties, theguarantee for a functional ageing management is the task of upper plantmanagement.
4、报告题目:用孔径聚焦反褶积模拟的背散射成像(数字射线专场)
Title of the report:Back Scatter Imaging – Simulation of Aperture Focusing by Deconvolution(Special Digital Radiography)
报告人:格尔德罗杰耶尼施博士
Reporter:Dr. Gerd-Rüdiger JAENISCH
单位:德国材料研究院
Unit:BAM
摘要Abstract:
X-ray backscatter imagingis a well-established NDT technique to inspect complex objects using only asingle-sided access. We present a specially designed multi-slit scatter cameraconsisting of several twisted slits which are parallelly arranged in a metalblock. The camera projects one image per slit to the digital detector array,where the images are overlaying each other. The aperture is corrected based ona de-convolution algorithm to focus the overlaying projections into a singlerepresentation of the object. In order to achieve high backscatter intensitiesfrom an object, it is necessary to optimize the parameters of the backscattersystem by simulation.
Keywords:back scatter imaging, computer simulation, aperture focusing, deconvolution
5、报告题目:核电站材料的衰老和退化特征的无损检测(核电专场)
Title of the report:NDT for characterizing Ageing and Degradation of Nuclear Power Plant Materials– Fatigue and Irradiation(SpecialNuclear Power)
报告人:格尔德道博曼教授
Reporter:Prof. Gerd Dobmann
单位:德国无损检测与质量保证协会
Unit:Expert in Non-Destructive Testing (NDT) andNuclear Energy Safety and Reliability by NDT-Use
摘要Abstract:
Following the designrules and considering the safety factors, the lifetime of nuclear power plants(NPP), worldwide is expected to be in the range of 40 years. Obviously, withinsuch a lifespan the components and systems under heavy mechanical (static anddynamic pressure, vibration), thermic and irradiation loads, suffer ageingphenomena which are Thermal Ageing, Corrosion, Low Cycle Fatigue (LCF), HighCycle Fatigue(HCF), Very high Cycle Fatigue (VHCF) and Irradiation Damage dueto neutrons – and the possible synergy of the phenomena together. However, theelectrical power producing utilities as operators of the NPP, perform a‘predictive maintenance’, also called ‘retrofitting’, by timely performing thereplacement of especially stressed components. Examples for these replacementprocedures are the change of heat-exchangers and parts of the main coolingpipes, like hot knees near heat-exchangers or components of the surge-line in pressurized-waterNPP. As the components, which are replaced, always are manufactured accordingthe newest technical state of the art, the retrofitting enhances inherentlyalso the safety standard. In Germany, where due to the ‘Atomic Law’, the safetyof the plants is asked for, this law – beside economic reasons of a highertechnical availability – is the driver for replacement. The IAAEA hatintroduced [1] safety standards for Ageing Management and according thesedocuments, worldwide most of the atomic energy producing countries have adoptedtheir national guidelines, newly introducing mainly fatigue conditionmonitoring.
In Germany, beginningvery early in 1978, in the so-called ‘Nuclear Safety Research Program, R&Dwas initialized to develop NDT procedures for ‘Materials Characterization’ aspreventive procedures, detecting the degradation of materials in terms ofchanges in the mechanical-technological properties, like strengtheningproperties as Yield- or Tensile-strength, or hardness- and toughness-changes.
The proposed paperdiscusses, on one hand, the application of the 3MA-strategy(Micromagnetic,Multiparameter, Microstructure and Stress Analysis) onferromagnetic components and Eddy-Current-based and Ultrasonic techniques onaustenitic materials for early-characterizing fatigued microstructures – beforecracking and, on the other hand, characterization of irradiation damage inpressure-vessel steels.
6、  报告题目:大量混凝土结构的超声波检测
Title of the report:Ultrasonic investigation of massive concrete constructions
报告人:恩斯特里德理新奇博士
Reporter: Dr. Ernst Niederleithinger
单位:德国材料研究院
Unit:BAM
摘要Abstract:
Ultrasonic imaging ofconcrete constructions was so far limited to a thickness of about one meter. Wehave developed a Large Aperture Ultrasonic System (LAUS), which has beensuccessfully tested for up to five meter thickness. Imaging methods adoptedfrom geophysics, e.g. Reverse Time Migration (RTM) help to improve the results.
Keywords: concrete;ultrasound; imaging,
7、  报告题目:磁共振成像和弛豫的无损检测
Title of the report:Magnetic Resonance Imaging and Relaxometry for NDT
报告人:菲利普莫奇博士
Reporter:Dr.Philipp Mörchel
单位:德国夫琅禾费集成电路IIS研究所
Unit:Fraunhofer Institute for Integrated Circuits IIS
摘要Abstract:
Magnetic resonance allowsa nondestructive access to numerous bulk and spatially resolved characteristicmaterial parameters. We developed a portable benchtop system which allows theacquisition of these parameters (even of solid samples) in the production line.
Keywords: magnetic resonance; relaxometry; imaging; monitoring
8、  报告题目:光子计数和射线成像的能量识别的探测器的近期发展(数字射线专场)
Title of the report:Recent developments of photon counting and energy discriminating detectors forradiographic imaging(Special Digital Radiography)
报告人:乌韦希尔本博士
Reporter:Dr. Uwe Zscherpel
单位:德国材料研究院
Unit:BAM
摘要Abstract:
The direct detection ofX-ray photons into electrical signals is allowed by usage of highly absorbingphoto conducting materials (e.g. CdTe) as detection layer of an underlying CMOSsemiconductor X-ray image detector.. If the read-out speed is high enough (ca.50 – 100 ns dead time) single X-ray photons can be counted and their energymeasured. Read-out noise and dark image correction can be avoided. By setting energythresholds selected energy ranges of the X-ray spectrum can be detected orsuppressed. This allows material discrimination or reduction of scatteredradiation, which results in an enhanced contrast sensitivity.
Keywords: industrial X-ray imaging; directdetection, digital detector array, dual energy imaging
9、  报告题目:太赫兹应用程序运用于无损检测(数字射线专场)
Title of the report:THz Applications for Non-Destructive Testing(SpecialDigital Radiography)
报告人:乔治贝克曼恩博士
Reporter:Dr. Joerg Beckmannr
单位:德国材料研究院
Unit:BAM
摘要Abstract:
Electromagnetic waves inthe frequency range between 0.1 and 10 THz are described as THz-radiation(T-ray). The ability to penetrate dielectric materials, to operate contactlessand to be non-ionizing as well as being insensitive to ambient temperaturesmakes THz technologies for NDT applications attractive especially where othertechniques are not available or less suitable. Today T-rays are applied innon-destructive testing for quality control and condition monitoring issues.The operation is based on the combination of both transmission and/orreflection measurements and specially developed reconstruction procedures.Firstly, THz-TDS measurements will be presented to demonstrate theopportunities for spectroscopy and imaging of polymer materials. A SAFTalgorithm and an Optical Layer-Model will be presented and discussed in moredetail to demonstrate the opportunities of image reconstruction forvisualization of the inner structures of optically and far infra-red opaquepolymer composites.
Keywords: THz radiation,Terahertz synthetic aperture focusing, dielectric materials, imagereconstruction
10、       报告题目:移动层析X射线检测(数字射线专场)
Title of the report: MobileTomographic X-Ray Inspection(SpecialDigital Radiography)
报告人:雷德默伯恩哈德博士
Reporter: Dr.Redmer Bernhard
单位:德国材料研究院
Unit:BAM
摘要Abstract:
A special 3D tomographicalgorithm was developed for mobile inspection of large objects. The method isbased on a coplanar scan of an X-ray tube parallel to the surface of a digitaldetector array (DDA). Two different designs were developed and applied for 3Dtesting of welded pipes in nuclear power plants and large aircraft componentsmade from carbon fiber reinforced polymers (CFRP). The reconstructed tomographicimages permit the detection, characterization and measurement of the dimensionsof flaws with enhanced sensitivity compared to conventional radiography and UT.
Keywords: computed tomography,laminography, weld inspection, fibre composites, aircrafts
11、       报告题目:用磁导率增量方法评价材料降解(电磁专场)
Title of the report: Evaluationof Material Degradation by Magnetic Incremental Permeability Method(Special Electromagnetism)
报告人:哲佑琦莫泰博士
Reporter: Prof.Dr. Tetsuya Uchimoto
单位:日本东北大学
Unit:Tohoku University Japan
12、       报告题目:激光超声在特种设备检验检测的应用前景(光声技术和超声检测专场)
报告人:郑凯
单位:江苏省特种设备安全监督检验研究院
13、       报告题目:连续激光超声和调控声波模式(光声技术和超声检测专场)
报告人: 沈中华
单位: 南京理工大学
14、       报告题目:超声检测仿真建模及其应用(光声技术和超声检测专场)
报告人:赵新玉
单位:大连交通大学
15、       报告题目:固体板中超声拓扑成像(光声技术和超声检测专场)
报告人:张碧星
单位:中科院声学所
16、       报告题目:高次模式谐振与非线性波融合在无损检测中的应用研究(光声技术和超声检测专场)
报告人:张辉
单位:南京大学声学所
17、       报告题目:光声频谱分析及其在生物医学应用(光声技术和超声检测专场)
报告人:陶超
单位:南京大学声学所
18、       报告题目:超声Lamb波成像检测方法研究(光声技术和超声检测专场)
报告人:刘增华
单位:北京工业大学
19、       报告题目:管道腐蚀电磁导波层析成像研究(光声技术和超声检测专场)
报告人:郑阳
单位:中国特种设备检测研究院
20、       报告题目:超声检测新技术及其在航空航天领域中的应用(光声技术和超声检测专场)
报告人:周正干
单位:北京航空航天大学
21、       报告题目:基于非线性超声导波的复合材料损伤检测方法(光声技术和超声检测专场)
报告人:李卫彬
单位:厦门大学
22、       报告题目:局部弹性常数的超声测量及声传播仿真(光声技术和超声检测专场)
报告人:宋波
单位:中科院声学所
23、       报告题目:木节的声检测方法的研究(光声技术和超声检测专场)
报告人:刘晓宙
单位:中科院声学所
24、       报告题目:反射横波筑底衍射纵波检测法
Title of the report: TheInspection Method of Reflecting Transverse Wave on The Bottom Surface-BreakingDefect Generate Diffraction Longitudinal Wave
报告人:杨育伟
Reporter: YangYuwei
单位:西安特种设备检验检测院
Unit:Xi 'an Special Equipment Inspection Institution
25、       报告题目:贴片天线在结构应力监测中的应用研究
报告人:宋国荣
单位:北京工业大学机电学院
26、       报告题目:核电阀门在役检测与诊断技术
Title of the report: Valvein service Inspection and Diagnostics Technology
报告人:杰西德利伽多博士
Reporter: Dr.Jesse Delegado
单位:美国西南无损检测技术公司
Unit:IHI
27、       报告题目:基于时间反转成像算法的超声阵列数据的预处理
Title of the report: Thepre-processing of ultrasonic array data for time-reversal-based imagingalgorithm
报告人:樊程广博士
Reporter:Dr. Fan Chengguang
单位:国防科学技术大学
Unit:National University of Defense Technology
28、       报告题目:基于广义时间反转成像的超声无损评价
Title of the report: A generalized time-reversal-based imagingfor ultrasonic non-destructive evaluation
报告人:樊程广博士
Reporter: Dr.Fan Chengguang
单位:国防科学技术大学
29、       报告题目:核电奥氏体不锈钢对接焊缝TOFD检测方法研究
报告人:彭召斌
单位:深圳市微声泰斯特科技有限公司
30、报告题目:管子管板角焊缝射线检测新型灵敏度试块——高仿型试块
报告人:强天鹏研究员
单位:江苏中特创业设备检测有限公司
