[官方发布] 公布远东论坛被IEEE和EI数据库收录的论文
查看17451 | 回复1 | 2016-3-17 10:17:45 | 显示全部楼层 |阅读模式
公布远东无损检测新技术论坛获IEEE和EI数据库收录的优秀英文论文
自2013年起,远东无损检测新技术论坛与IEEE和EI建立合作关系,推荐优秀英文论文供IEEE和EI数据库收录。2013/2014/2015三届论坛共有150篇论文被收录,现将被IEEE和EI数据库收录的150篇优秀论文的题目、作者公布如下:
2013远东无损检测新技术论坛获IEEE和EI数据库收录的优秀英文论文:
1 Saturated Low Frequency Eddy Current Technique Applied toMicrostructure Phase
Quantification in Duplex Stainless Steel
Joao M. A.REBELLO; Maria C. L. AREIZA; Cesar G. CAMERINI; Joao V. ROCHA
2 Applications of Approximate Wave Analysis to Ultrasonic Flaw Imaging
Sohichi Hirose
3 Detection and Classification of Weld Defects in Industrial Radiographywith Use of
Advanced AI Methods
Ryszard SIKORAiotr BANIUKIEWICZ; Tomasz CHADY; Przemysław ŁOPATO;
Bogdan PIEKARCZYK;Grzegorz PSUJ; Bogdan GRZYWACZ; Leszek MISZTAL
4 Efficient Analytical Modelling for Pulsed Remote Field Eddy CurrentEvaluation of
Stratified Tubular Structures
Yong LI;Xiangbiao LIU; Yong QI; Zhenmao CHEN
5 Ultrasonic weighted imaging of synthetic aperture focusing techniquebased on the
correlation of signals
Lin Luo; YangYang; Jianping Peng; Jing Li; Xiaorong Gao; Kai Yang; Jinlong Li
6 Electromagnetic System for Nondestructive Evaluation of Train HollowAxles
Tomasz CHADY;Grzegorz PSUJ; Jacek KOWALCZYK; Ireneusz SPYCHALSKI
7 The Study on the Nonclassical Nonlinear Effect of Concretes withDifferent Mix Rate
Lue ZHANG;Xiaozhou LIU; Xiaohui WANG; Jiehui LIU; Jianjun CHEN; Xiufen GONG
8 wheel and axle defect detecting technique using phased array ultrasonic
Xiaorong GAO;Jianping PENG; Yu ZHANG; Chaoyong PENG; You TAN
9 Reconstruction of Deep Stress Corrosion Crack Based on aMulti-objective
Optimization Evaluation from Eddy Current Testing Signals
Li WANG; HongmeiLI; Zhenmao CHEN
10 MFL Inspection Defect Reconstruction Based on Self-learning PSO
Wenhua HAN; JunXU; Guiyun Tian
11 Sizing of Cavity Defect in Metallic Foam from DC Potential DropSignals with
Stochastic Inversion Methods
Xiaojuan WANG;Shejuan XIE; Xiaowei WANG; Zhenmao CHEN
12 Simulation on Quantitative Analysis of Crack Inspection by Using EddyCurrent
Stimulated Thermography
Feng LIU;Suixian YANG; Chunhu LENG; Zhenwei SU
13 Ultrasonic Inspection of Complex Composite Parts 65
Hongbo WANG;Chunguang XU; Yao XU
14 Thermal reliability evaluation of PLCC packaging using scanningacoustic microscopy
Xianghui GUO;Chunguang XU; Liu YANG; Kai PENG
15 Benchmark of Residual Stress for Ultrasonic Nondestructive Testing
Wentao SONG;Qinxue PAN; Chunguang XU; Xiao LI; Haiyang LIU
16 Time Delay Estimation via Third-order Cumulant
Shiyuan ZHOU;Yao XU; Hongbo WANG; Chunguang XU
17 Immersion Ultrasonic Reflection Tomography by Annular Array System
Liu YANG; QinxuePAN; Chunguang XU; Xianghui GUO; Kai PENG
18 Plate Components Ultrasonic Guide Wave Detection Based on theTransducer Array
Xipeng Li;Chunguang Xu; Shiyuan Zhou; Dingguo Xiao
19 Single Channel Blind Source Separation for Defect Identification UsingEddy Current
Pulsed Thermography
Bin Gao; LibingBai; W.L. Woo; Gui Yun Tian; Yuhua Cheng
20 Electromagnetic imaging techniques for NDE applications a review
Yuhua Cheng;Libing Bai; Xin Xiong; Taiping Wang; Gui Yun Tian
21 Experimental study of alternating current stress measurement under auniaxial stress
Shangkun Ren;Wei Fan; Ruiqi Zhou; Bing Li
22 R & D to Electromagnetic NDT in the German Nuclear Safety ResearchProgram –
Material Characterization of Ageing Phenomena and Online Monitoring ofFatigue and
Fracture-Mechani
Gerd DOBMANN;Christian BOLLER; Hans Georg HERRMANN; Iris ALTPETER
23 Study on the railway wheel ultrasonic inspection method using the fullmatrix capture
Jianping PENG;Hua PENG; Yu ZHANG; Xiaorong GAO; Chaoyong PENG; Zeyong WANG
24 A Voltage-Current Method of Measuring Ultrasonic Transducer Impedance
Qinxue PAN;Dingguo XIAO; Mingkai DENG; Huiling REN; Yao XU; Chunguang XU
25 Ultrasoud detection based on confocal Fabry-Perot interferometer
Shaoze Wang;Xinyu Zhao; Zongxing Lu
26 Response Characteristics of ultrasonic transducer under differentexcitation pulses
Dingguo XIAO;Huiling REN; Jiameng SHAO; Chunguang XU
27 Properties of Copper Film Characterized by Scanning AcousticMicroscope
Hongjuan YAN;Kai PENG; Chunguang XU; Qi LIN
28 Ultrasonic Automatic Scanning for Arbitrary Rotator 145
Xiandong CAO; QinxuePAN; Chunguang XU; Shiyuan ZHOU; Haichao CAI; Fanwu
MENG
29 Influence of Coil Parameters on Transduction Performance ofUnidirectional EMATs
for Rayleigh Wave
Xiaoyang CHEN;Riliang SU; Heng ZHANG; Shujuan WANG; Guofu ZHAI
30 Research on the device of differential excitation type eddy currenttesting for metal
defect detection
Minghe CAO;Weimin ZHANG; Weiqin ZENG; Chengfeng CHEN
31 Some studies on ultrasonic defect inspection for small diameterthin-walled steel tubes
Pengfei Zhang;Xiufen Zhao; Ying Yin; Guofu Yin
32 Defect mapping of steel substrate under fire protection layer using EMNDE methods
Ibukun D.Adewale; Hong Zhang; Gui Y. Tian; Tom Hope
33 Research on detection sensitivity based on wave structure of Lamb wave
Xingang LI;Yuemin WANG; Guozhi SONG; Xiaodan SUN; Xiaoyu SUN
34 Evaluation Measurement of Accuracy of Industrial Computed Tomography177
Si Chen; HaoChen; Shi-gen Li; Jing Li; Shou-tao Li
35 Method of ultrasonic phased array imaging based on segment amplitudeapodization
Jianqiang Guo;Lin Chen; Yu Zhang; Kai Yang; Jinlong Li; Xiaorong Gao
36 X-ray analysis on crystal structures of crystalline polyimides
Wei WANG;Junhong LI; Songbai HAN; Kai SUN; Hongli WANG; Yuntao LIU; Dongfeng
CHEN
37 A portable inspection instrument based on electromagnetic acoustictransducer
Yakun WANGengzhan LI; Bo LIU; Guofu ZHAI
38 Development of Non-Contact Air Coupled Ultrasonic Testing System forReinforced
concrete Structure
Junjie CHANG;Chao LU; Koichiro KAWASHIMA
39 Detection of Plastic Deformation of 304 Austenitic Stainless SteelBased on DC
Magnetization
Hongmei LI; LiWANG; Yong LI; Zhenmao CHEN
40 Laser ultrasonic technique applied to inspect fatigue crack 205
Yang ZHAO; JianMA; Shuai LIU; Rui GUO; Jiangfeng SONG; Zhongqing QING
41 Multi-voltage Digital Radiography Images Fusion Based on GrayConsistency
Jiaotong WEIing CHEN; JinXiao PAN
42 Identification of defects in HDPE piping thermal fusion welds based onmicrowave
inspection and true density measurement
Xinwei ZHU;Jinping PAN; Lianjiang TAN
43 Railway wheel defect dynamic inspection system based on ultrasonictechnology
Chaoyong PENG;Xiaorong GAO; Zeyong WANG; Quanke ZHAO; Yu ZHANG; Jianping
PENG; Kai YANG
44 Research on Acoustic Emission Characteristics of Honeycomb SandwichComposite in
Compression Damage
Guanhua WU; SiyiLIU; Wei WU; Puxiang Han
45 Design of a High Voltage Pulse Circuit for Exciting Ultrasonictransducers 224
Dingguo XIAO;Jiameng SHAO; Huiling REN; Chunguang Xu
2014远东无损检测新技术论坛获IEEE和EI数据库收录的优秀英文论文:
1 Designof TOFD Receiving Filter On DSP Builder
JinWang , Hao Liu and Zhong-chang Chen
2Simulation-aided UT Weld Inspection for Improving Integrity During PipeManufacture
JoãoMarcos A. REBELLO , Mariana BURROWES , Gabriela Ribeiro PEREIRA , Luís Marcelo
TAVARES, Marcos PONCIANO, Robson MANAO
3 A NewSurface-Wave EMAT Design of Enhanced Transduction Efficiency
LeiKang, Feng Pan, Riliang Su, Chao Zhang, Jingmin Dai
4 AnInspection Device Based on Multiple Lamb Wave Electromagnetic AcousticTransducers
Guo-fuZHAI, Bo LIU, Chao-ran DENG, Yong-qian LI, Lei KANG
5 Studyon Complicated nonlinear phenomena in ultrasonic infrared thermography usingcircuit simulation method
KaiZHENG, Jiang ZHENG, Shuyi ZHANG
6Application of a non-contact laser ultrasonic imaging technique in surfacedefect detection
WeiZENG, Hai-tao WANG, Gui-yun TIAN, Guo-xing HU, Xian-ming YANG, Min WAN
7Modified Synthetic Focusing with Direction of Arrival Function for UltrasoundImaging
Yun-caiLi, Lin Luo , Ze-yong Wang, Xiao-rong Gao ,
8 AGuided Wave Approach for Real-time Health Monitoring of High-Speed Train BogieFrames
MingHONG , Qiang WANG , Zhongqing SU ,
9Efficient Imaging Techniques Using Sub-aperture Matrix Capture andTwo-dimensional Sparse Array
YunYang, Jianqiang Guo, Xiaorong Gao, Jing Li, Jianping Peng, Biao Zheng, Hua Peng
10 Theefficiency optimization of full matrix capture imaging detection based onincreasing the effective aperture
HuaPENG, Jian-ping PENG, Hong-na Zhu, Ze-yong WANG, Xiao-rong GAO
11Effects of directivity function on total focusing method imaging performance
XiangZhou, Jian-ping PENG, Lin Luo , Ze-yong Wang, Xiao-rong Gao
12Efficiency improvement of total focusing imaging based on sparse array method
TaoPeng , Jian-ping Peng , Hua Peng , Li Wang, Xiao-rong Gao, Lin Luo, Jin-long Li
13 LaserUltrasonic Inspection in Ablation Regime
Jin-GyumKim , Sunghee Yoon , Jooho Lee, Kyung-Young Jhang
14Ultrasonic array time-reversal based super resolution imaging
ChengguangFan, Mengchun Pan, Dixiang Chen, Yunze He, Feilu Luo
15Correction technique of phase aberration in ultrasonic synthetic focusingsignal
Hai-linYue , Lin Luo, Xiao-rong Gao ,
16Automated non-contact NDT by ultrasonic surface waves
QiangLIU , Bogdan PIWAKOWSKI , Zoubeir LAFHAJ , Kahina AGRED
17Ultrasonic TOFD image registration algorithm of sub-pixel accuracy based on DFT
WUYing-yong ,GAO Xiao-rong , GUO Jian-qiang, WANG Ze-yong , ZHAO Quan-ke , SHEN
Yan
18 PhasedArray B-scan Acoustic Field Simulation of Aluminum Extrudate FSW Welds with ComplexShapes
ChangxiWang, Long Wang, Changli Sun, Tie Gang .Jingho ng Yang , Xinmeng
Zhang,ChangqingXia,Yan Jiang, Zhanqi Yan
19AMultichannel Data Acquisition System Design for Ultrasound Guided WavesTesting
LeiZhang
20 Threedimensional imaging based on ultrasonic linear phased array probe
ChangliSun , Tie Gang , Changxi Wang ,Jinghong Yang , Xinmeng Zhang , Changqing Xia ,
ZhanqiYan , Yan Jiang
21Radiation Pattern of Lamb Waves Generated by Electromagnetic AcousticTransducers
BoLIU, Chao-ran DENG, Chuan-liu JIANG, Guo-fu ZHAI, Lei KANG
22Numerical Simulation of Magnetostrictive Lamb Wave EMATs on Steel Plate 107
Ri-liangSU , Shu-juan WANG , Guo-fu ZHAI
23 DefectDetection Study on Total Focus Method of Sound Field Imaging Based on Parallel Processing
ZHANGXinlu, GUO Jianqiang, LUO Xiaoxiang, GAO Xiaorong, WANG Zeyong, ZHAO
Quanke,ZHENG Biao
24Thickness of Coating Tested Nondestructively Based onWelch Frequency
QiLIN , Chun-guang XU , Hong-juan YAN ,Shi-yuan ZHOU , Liu YANG
25Straight Wave UT Technical for Dissimilar Metal Weld of Nozzle to Safe-End inReactor Pressure Vessel
YINQin, LI Yulong
26Research on Ultrasonic Inspection of Control Rod Drive Mechanism Housing Weldin Chinese Evolutionary Pressurized Reactor Nuclear Power Plant
HuaidongCHEN,Zhe YU,Weiqiang WANG,Guanbing MA,Maocheng HONG
27Electromagnetic Ultrasonic Guided Waves Inspection of Rail Base
Shu-juanWANG, Xiao-yang CHEN, Tao JIANG, Lei KANG
28 AnIncident Angle Optimization Method for Transverse Defects Detection of PipesBased on Zoeppritz's Equation
Shi-yuanZHOU, Hao-yuSUN , Ding-guo XIAO , Chun-guang XU , Li-ming CUI , Liu YANG
29 UltrasonicTransmission Detection Technique of Complex Rotating Surface Based On Complex AxisMotion
JuanHAO , Zhi-gang ZOU , Chun-guang XU , Fan-wu MENG4, Shi-yuan ZHOU5
30Kinematic Analysis and Simulation of Ultrasonic Testing Manipulator
XinliangLI,Xinyu ZHAO, Juan HAO, Zongxing LU, Ye HUANG,Liu YANG
31 ThePost-processing Technology of Ultrasound Scanning Point Position Based onAutomatic Programming
YeHUANG, Juan HAO, Zhen XIAO,Xinliang LI, Zongxing LU, Liu YANG
32Optimization of Lamb Wave Parameters in Mechanical Damage Evaluation of Z CN 8.N Welding Joint
ZhongbingLuo, Huanqing Cao, Lijuan Meng, Li Lin
33Residual Stress Nondestructive Testing for Pipe Component Based on UltrasonicMethod
Wen-taoSONG, Qin-xue PAN, Chun-guang XU, Xiao LI, Xin JIN, Huan-xin LI, Shuai LIU
34Application of Phased Array Ultrasonic Inspection for EMUs Wheel-set Online
YuZHANG , Jian-ping PENG , Xiao-rong GAO , Chao-yong PENG
35 LowFrequency Eddy Current Inspection ofWall-thinning of Large Pipe by Bobbin Coils
JingWANG, Noritaka YUSA, Hiroyuki FUKUTOMI , Hidetoshi HASHIZUME
36Rolling Contact Fatigue detection using Eddy Current Pulsed Thermography
JianpingPENG, Guiyun TIAN, Li WANG, Xiaorong GAO, Yu ZHANG, Zeyong WANG
37Surface Crack Detection for Carbon Fiber Reinforced Plastic (CFRP) MaterialsUsing Pulsed Eddy Current Testing
JialongWu, Deqiang Zhou , Jun Wang, Xuedong Guo, Lihua You, Wei An, Hong Zhang
38 EddyCurrent Test Research for Eccentricity of International ThermonuclearExperimental Reactor (ITER) in-vessel coils (IVCs) conductor
XiaochuanLiu , Yu Wu , Zhenmao Chen , Hongda Zhao , Wenlu cai , PatrickVertongen
39Simulation Study on Quantitative Evaluation of Crack Depth in Crack Inspectionwith Eddy Current Stimulated Thermography
Xiang-xiangYI, Jin-jing ZENG, Sui-xian YANG
40Emissivity-adjusted based depth profiling in eddy current pulsed thermography
KongjingLi, Gui Yun Tian
41Thermography Spatial-Transient-Stage Mathematical Tensor Construction andMaterial Property Characterization
BinGao, Aijun Yin , Yizhe Wang , Guiyun Tian , W.L. Woo, Hanxiao Liu
42 Anovel flexible eddy-current probe with high sensitivity
RuifangXie, Weihong Zhou,Dixiang Chen, Mengchun Pan, Ying Tang
43 EarlyContact Fatigue Evaluation of Gear Using Eddy Current Pulsed Thermography
JiaLiu ,Wenwei Ren , Gui Yun Tian , Bin Gao , Jin Song Meng , Yizhe Wang
44 GiantMagneto resistance Based Eddy-Current testing system
Wangchen , Zhao yulu , Fan jingjing, Zhang xiaojuan
45Research on the principle of railway wheel out-of-roundness on-line dynamicdetecting system based on Laser measurement
Yangkai,Gaoxiaorong, Dailixin,Xieliming, Zhangyu,Pengchaoyong,Pengjianping
46Influence of laser beam profiles on the frequency bandwidth of laser-generated surfaceacoustic waves
HogeonSeo , Sungho Choi , Kyung-Young Jhang
47 TheInteraction of Multiple Magnetic Circuits in Magnetic Flux Leakage (MFL)Inspection
GaoTing-yan , Yu Yong-liang , Han Tian-yu , Wang bo
48 Thestudy on seal detection of high pressure flange based on metal magnetic memorytechnology
JiashunHu, Wenyong Sun, Yongtao Zhao , Wencai Liu
49 Thedetection of axial cracks in pipe string using a feed-through ACFM probe
Xin-anYUAN, Wei LI, Guo-ming CHEN, Xiao-kang YIN, Jiu-hao GE, Chuan-rong ZHANG
50 A FastAnalytical Model of Electromagnetic Acoustic Transducers for Evaluation of Flat
Non-magneticConductors
YongLI, Yi-li LI, Zhen-mao CHEN
51 Designof bulk wave EMAT using a pulsed electromagnet
HengZHANG, Ri-liang SU, Shu-juan WANG, Guo-fu ZHAI, Lei KANG
52Simulation-based Analysis of Probe-type Electrostatic Sensors’ Spatial DynamicSensitivity
TangXin , Li Yue , Cheng Zhongsheng , Hu Zheng , Yang Yongmin
53 BrokenWires Inspection for Coated Steel Belts in Elevator System Using MFL Method
Hua-mingLei , Run-hua Liang , Wei Tao , Yi-mei Mao , Hui Zhao
54Barkhausen Noise Application Research in RPV Irradiation EmbrittlementDetection
MingliangFan, Haitao Wang, Lingyun Wu, Wangjie Qian, Xiangbing Liu
55Composite Railway Health monitoring System Based on Fiber Optic Bragg Gratingsensing array
MiQiushi, Gao Xiaorong, Zhu Hongna,Wang Zeyong, Zhao Quanke
56Application of FTP in flaw detection of rail web*
Sheng-xiHE , Jin-long LI , Xiao-rong GAO , Lin LUO
57 FTP DRestructure Using in Smooth tracks
YueYu , JingLong Li , Xiaorong Gao , Lin Luo
58 ANovel Way to Process Light-Section Image of Wheel Set Outline Based on B-SplineFunction
JingLI, Xiaorong GAO,Kai YANG
59 A NewViewpoint About AR Model
ZhizhongLUO
60 TheResearch on Measuring Magnetic Tile Size Based on Image Processing 284
LINLijun, YIN Ying
61 Leakdetection by testing vapor in tank foundation
Xiu-MeiShu , Hua-Nan Li , Ze-Nong Qin , Li-Chuan Liu , Ming-Xi Deng , Dong-Mei Zhang
62Analysis of Electromagnetically Induced Acoustic Emission under DifferentMagnetic Field conditions
ZhichaoCai , Suzhen Liu , Chuang Zhang, Qingxin Yang
63Application of acoustic emission technology in fixed thickness measurementtechnology
WencaiLiu ,Daqing Song ,Yan Wei ,Jiashun Hu
64 Thedefects recognition of wheel tread based on linear CCD
WenZhang, Yu Zhang, Jinlong Li, Xiaorong Gao, Li Wang
65Dynamic analysis of Vehicle-Track Coupling system due to a wheel flat
YuWang,Ji yang Han, Kai Yang, Lin Luo
66 Windspeed forecasting based on Time series - Adaptive Kalman filtering algorithm
YunxiangTian,Qunying Liu ,Zhiyuan Hu ,Yongfeng Liao
67 Studyon edge effect of Radiographic Testing for Titanium Alloy Joint Structure withLarge Thickness Difference
WuWei ,Hu Li ,Zhang Xiang-lin , Xiao Yu-xing , Wu Guan-hua
68 RecentDevelopments in Pulse Reflectometry for Tube Inspection
Dr.Noam Amir
69 A NewImproved Synchrosqueezing Transform Based on Adaptive Short Time FourierTransform
YanjieGuo, Zuowei Fang, Xuefeng Chen
70 ZigbeeNetwork-based Detection of Anomaly Detection Runway on Airport
Ji-hongZHANG, Xing-wang LI, Jie QIAN
71Innovative Solution for Ultrasonic Fabrication Test of Railroad Wheels
WolfgangKAPPES , Werner BÄHR , Wolfgang SCHÄFER , Thomas SCHWENDER ,Andreas
KNAM, Frank KNAPP
72Modelling and experimental study of magnetic induction spectroscopy for raildecarburization measurement
W.Zhu, W.Yin, C.L.Davis, P.Hunt, S.Dewey, A.J.Peyton
73Simulation for magnetic flux leakage signal interpretation --A FE-approach tosupport in-line magnetic pipeline pigging
IsabelCristina PEREZ BLANCO, Jorge H. PANQUEVA ALVAREZ, and Gerd DOBMANN
74Development of an advanced ultrasonic inspection tool for rapid volumetricexamination of aluminothermic rail welds
LuZHAO, John RUDLIN
75 AnEvolution of RFID Grids for Crack Detection
JunZHANG, Guiyun TIAN
76 TheInfluence of MEMS on Electromagnetic NDT
MengchunPan, Yunze He, Ruifang Xie, Weihong Zhou
2015远东无损检测新技术论坛获IEEE数据库收录的优秀英文论文
P0001 From NDT to Prognostics: Advanced echnologies For Improved Quality,Safety And Reliability
Leonard J. Bond
Center forNondestructive Evaluation (CNDE)
Department ofAerospace Engineering & Department of Mechanical Engineering
Iowa StateUniversity, Ames, IA 50011, USA
P0005 Innovative RoboticTechnology for Monitoring the Integrity of Generator Retaining Rings
Mark SAVENKOV1, Michael TURNER1, Andres PERALTA-GORISSE2
1ALSTOM Power Thermal Services Asia
2ALSTOM Power Thermal Services Switzerland
P0064 Ultrasonic SignalCompressive Sampling and Its Application in Pipeline Flaw Inner Inspection
Shou-peng SONG , Ying-xue LI, Yun-jiao WANG, Ying DU
Department ofInstruments Science and Engineering, Jiangsu University ,Zhenjiang , China
P0065 Study on FocusingCharacteristics of Curved Phased Array Probe
Huan-qing CAO, Zhong-bing LUO,Bo-kun ZHOU, Hui-min SU, Li LIN
NDT & E Laboratory, Dalian University of Technology,Dalian 116085, China
P0073 Electromagnetic ultrasonictomography of plate defects based on omnidirectional Lamb-wave EMATs
Lei KANG1, Chao ZHANG1, Ping CHEN2, Jianguo LI1, Yixuan ZHANG1
1School ofElectrical Engineering and Automation, Harbin Institute of Technology, Harbin,China
2PowerEconomics and Technology Institute, SMEPC, Shanghai, China
Emailaddress:victorkang11@126.com
P0087 Implementing UltrasonicGuided Wave Mode Control in Hollow Cylinders
Xiaowei Zhang1, Zhifeng Tang2,Sujun Luo3, Fuzai Lv1, Ye Han4
1Institute of Modern Manufacture Engineering, ZhejiangUniversity, Hangzhou China 310027
2Institute of Advanced Digital Technologies andInstrumentation, Zhejiang University, Hangzhou China 310027
3Hangzhou Zheda Jingyi Electromechanical TechnologyCorporation Limited, Hangzhou China 311121
4Sinopec Oil&Gas Pipeline Inspection Corporation Limited, Xuzhou China221008
P0089 The Design &Implementation of Three-dimensional Analysis and EvaluationSystem of Sludge inNuclear Power Evaporator
Qianfei Yang, Keqing Wang, Yusu Chen, Lei Zhao
CGNPC InspectionTechnology Company Ltd Suzhou 215004
P0104 Application ofacoustoelasticity in studying compressive stress state inPolymer bondedexplosive
Yao XU1, Zhan-feng YANG1,Hai-qiang ZHOU1, Wei-bin ZHANG1
1Institute of chemical materials, China academy of engineering physics,Mianyang, China, 621900
P0121 The experimental research oflow-energy impact damage of carbon fibercomposite materials
Guan-hua WU1, E ZHOU2, Ru WANG3, Qi Zhang4 ,Ting-ting Zheng5
1, 3,5KeyLaboratory of Nondestructive Testing( Ministry of Education) ,Nanchang HangkongUniversity , Nanchang, 330063,China
2MechanicalEngineering Company of Jiangbei,Hubei Sanjiang Aerospacef,Xiaogan,432000,China
4Nanchang Branchof Jiangxi Special Inspection Institute, Nanchang, 330063,China
P0129 Study of Image FusionAlgorithm to Edge erosion of Titanium Alloy with DR Detection
Wu Wei1,Xiang-linZhang 2,HuLi1,Guan-huaWu 1
1 KeyLaboratory of Nondestructive Testing( Ministry of Education) ,Nanchang HangkongUniversity , Nanchang 330063, China
2 Beijing XinghangElectrical and Mechanical Equipment Company Limited,Beijing 100074,China
P0132 The optimization oftransducer layout in rail flaw detection
Lei ZHANG 1,a* , Xiao-rong GAO2, b, Wo WANG3, c and Chao-yong PENG2, d
1 IntelligentTransportation System Research Center, Southeast University, Nanjing 210096,China
2 School ofPhysical Science and Technology, Southwest Jiaotong University, Chengdu 610031,
P0140 Research on guided waveexcitation mode control method of comb transducer
Jun-qiang FU, Shi-yuan ZHOU, Zhe LI, Chun-guang XU, Qin-xue PAN
School of MechanicalEngineering, Beijing Institute of Technology, Beijing 100081, China
P0146 Fast total focusing methodby a migration approach
Ewen CARCREFF1, Guiyang LV2, Dominique BRACONNIER1
1The PhasedArray Company, 9078 Union Centre Blvd., suite 350, West Chester, Ohio, USA
2AOS ChinaCo.,ltd, Building 3, No.399,West Gumei Road, Minhang District, Shanghai, China
P0154 An Investigation and Reviewinto Microwave Thermography for NDT and SHM
Ruizhen YANG1,*, Hong ZHANG2, Teng LI3, Yunze HE4,*
1Department ofcivil and architecture engineering, Changsha University, Changsha, China
2School ofElectronic and Information Engineering, Fuqing Branch of Fujian NormalUniversity, Fuqing, China
3 School ofElectrical Engineering, Beijing Jiaotong University, Beijing, China
4College ofMechatronics engineering and automation, National University of DefenseTechnology, Changsha, P. R. China
P0156 Measurement of ResidualStresses in Materials and Welded Elements Using Ultrasonic Method
J. Kleiman and Y. Kudryavtsev
Structural Integrity Technologies (Sintec_ Inc. , 80 Esna Park Drive,Units 7-9, Markham, Ontario, L3R 2R7 Canada
P0159 Acoustoelastic Lamb waveanalysis in thin plates
Ning Pei1, Leonard J. Bond2
1,2Center forNondestructive Evaluation, Iowa State University, Ames, USA
P0184 Reseach on the UltrasonicTest System for the Complex Curved Surface Based on Robot
Fangfang LIU,Chunguang XU, Yazhou HE , DingguoXIAO,FanwuMENG,ZhenXIAO,
Qinxue PAN
Schoolof Mechanical Engineering, Beijing Institute of Technology, Beijing 100081,China
P0189 Analysis of DynamicCharacteristic for Ultra-thin Coating Layer with Ultrasonic Atomic ForceMicroscopy
Dong Ryul Kwak, Seung Bum Cho, Ik Keun Park†
Department ofMechanical & Automotive Engineering, Seoul National University of Scienceand Technology, Seoul, Korea
P0196 Research on Algorithms ofVarious Defects Detection of Thick-wall Pipes 192
Liming CUI1, Shiyuan ZHOU1, HaoyuSUN1, Qianhong LEI2,
Siyuan MA1, Xizhi TIAN2, Ping ZHANG2
1School ofMechanical Engineering, Beijing Institute of Technology, Beijing, 100081, China
2ChongqingJianshe Industry(Group)Co.,Ltd, Chongqing, 400054, China
a) Correspondingauthor: zhoushy@bit.edu.cn
P0198 Ferrite-yoke based pulsedinduction thermography for cracks quantitative evaluation
Yunlai Gao1,2*, Gui Yun Tian1,2*, Ping Wang1, Haitao Wang1, Juan Ji1,Song Ding1 1College of Automation Engineering,Nanjing University of Aeronautics and Astronautics, Nanjing, PR China 2Schoolof Electrical and Electronic Engineering, Newcastle University, Newcastle UponTyne, UK Corresponding Authors:
P0205 The effect of stress on thedomain wall behavior of high permeability grain-oriented electrical steel
Fasheng Qiu 1, Wenwei Ren1*, Gui Yun Tian1, Yunlai Gao2, Bin Gao1
1 School ofAutomation Engineering, University of Electronic Science and Technology OfChina, Chengdu, China,
2College ofAutomation Engineering, Nanjing University of Aeronautics and Astronautics,Nanjing, China
P0212 An Investigation intoAtmospheric Corrosion Detection under Paint with K-band Microwave NDT
Hong ZHANG1, Lin Xu2, Luxiong XU1, Jusheng Wu3, Yunze HE4
1School ofElectronic and Information Engineering, Fuqing Branch of Fujian NormalUniversity, Fuqing, China
2The Instituteof Innovation Information Industry, Fuqing Branch of Fujian Normal University,Fuqing, China
3Institute ofApplied Electronic Technology, Fuqing Branch of Fujian Normal University,Fuqing, China
P0213 Cross-correlation PhaseCorrection Method on Ultrasonic Synthetic Focused Signal Distortion
Cai-qun YE, Lin LUO *, Xiao-rong GAO, Li-rong JIANG, Hai-lin YUE
1 PhotoelectricEngineering Institute, Southwest Jiaotong University, Chengdu 610031, China
2 SouthwestJiaotong University NDT Research Center & Olympus NDT Joint Laboratory ofNondestructive Testing, Chengdu 610031, China
P0239 Research and Design of CNGGas Well Detection System
Xu Xiaodan1,Guo Zhenxiang2, Ren Yi1,Ding chunxiong1, Wang Haitao3, ZhengKai1, Song Wei2, Wang Jin1,Liang Zhaoming3, Kong Desuo3, Wu Lingyun3
1. SpecialEquipment Safety Supervision Inspection Institute of Jiangsu Province
2. Nantong UnionDigital Technology Development Company
3. NanjingUniversity of Aeronautics and AstronauticsCollege ofAutomation Engineering
P0241 Propagation oflaser-generated visco-elastic Rayleigh-like waves in coatings 240
Qing-bang HAN, Xue-ping JIANG, Jing JIA, Chang-ping ZHU
College of IOTEngineering Hohai university ,Chamngzhou, China
P0254 Motion simulation of robotfor nuclear reactor pressure vessel non-destructive detection based onSoftMotion
Ke-qing Wang, Wen-xin Xiang, Ge Lin, Huai-dong Chen, Chun-bing Shao, MingLi, Zhong-yuan Lin
CGNPC InspectionTechnology Co. Ltd191 Yangpu Road, Suzhou Industrial Park 215021,Suzhou , P.R.China
P0255 Investigation onconductivity invariance in eddy current NDT and its application on magneticpermeability measurement
Yating YU, Yu ZOU, Ming JIANG,Dejun ZHANG
School of Mechatronics Engineering
University of Electronic Science and Technology of ChinaChengdu,P.R.China 611700
P0257 Ultrasonic Inspection ofPartially Completed Welds Using EMAT-Generated Surface Wave Technology
Huidong Gao1, Borja Lopez1,Xavier Minguez2, Jianbin Chen3
1. Innerspec Technologies, Inc, Lynchburg, VA, USA
2. Innerspec Technologies Europe, Madrid, Spain
3. Nanjing Entry-Exit Inspection and Quarantine Bureau, Nanjing, China
P0259 Detecting non-magneticconducting flat plates with pulsed remote eddy current field technique
Bin-feng Yang1, Hui Zhang2,Chao Zhang1, Hai-xia Cao2
1 School of information and Navigation, Air ForceEngineering University,Xi’an 710077,China.
2 Department of Scientific Research, Air Force Engineering University, Xi’an710051,China.
P0262 Research on Axle Press-fitDefects Detection Optimizing
Chao-yong PENG1, Xiao-rong GAO1, Yang YANG2, Ai WANG2, Dong-dong WU2,Jia-yu ZHAO3
1School ofPhysical Science and Technology, Southwest Jiaotong University, Chengdu,Sichuan Province, China
2Chengdu LeadScience & Technology Co., Ltd., Chengdu, Sichuan Province, China
3Chengdu ForeignLanguage School, Chengdu, Sichuan Province, China
ccsccscao | 2016-6-1 15:25:52 | 显示全部楼层
真心的看不懂啊
