[请教] 涡流检测标准理解
查看4909 | 回复3 | 2014-12-9 20:37:07 | 显示全部楼层 |阅读模式
1.         BS EN1971-1999copper and copper alloy-eddy current test for tube: 怎么理解“ theacceptance criteria, detection of local discontinuities by encircling coilssystem and detection of non-local discontinuities by encircling coil systemswith lower detection levels?”
2.        In the criteria BS EN1971-1999copper and copper alloy-eddy current test for tube:
K2=(signal for the lower detection thresholds)/(signal for the normal detection threshold)怎么理解这个公式的?
3.
In the criteria BS EN1971-1999 copper and copper alloy-eddy current test for tube: d0=N0/L0 ,怎么理解这个公式的?
丁伟臣 | 2014-12-13 16:52:28 来自手机 | 显示全部楼层
可与我联系,我们提供欧标涡流2级培训发证服务。
yanyingjuanli | 2014-12-16 20:51:50 | 显示全部楼层
EN473的证书?
丁伟臣 | 2014-12-18 23:38:15 来自手机 | 显示全部楼层
yanyingjuanli 发表于 2014-12-16 20:51
EN473的证书?
现在更改为EN ISO9712证书了
