[分享] 美国ASTM无损检测标准目录(2005年版)
查看9846 | 回复2 | 2013-8-11 14:51:18 | 显示全部楼层 |阅读模式
ASTM
Volume 03.03, October 2005
Nondestructive Testing
Table of Contents
2005年版ASTM标准年鉴03.03卷无损检测标准目录
E0094-04
Guide for Radiographic Examination
射线照相检测指南
E0114-95R01
Practice for Ultrasonic Pulse-Echo Straight-Beam Examination by the Contact Method
接触式超声脉冲回波直射检测方法
E0125-63R03
Reference Photographs for Magnetic Particle Indications on Ferrous Castings
铸铁磁粉显示参考照片
E0127-05
Practice for Fabricating and Checking Aluminum Alloy Ultrasonic Standard Reference Blocks
铝合金超声参考试块制作和校验方法
E0155-00R05E01
Reference Radiographs for Inspection of Aluminum and Magnesium Castings
铝和镁铸件检测参考射线照相底片
E0164-03
Practice for Ultrasonic Contact Examination of Weldments
焊接件接触式超声检测方法
E0165-02
Test Method for Liquid Penetrant Examination
渗透检测方法指南
E0186-98R04E01
Reference Radiographs for Heavy-Walled (2 to 4-in. \[51 to 114-mm\])) Steel Castings
大厚度(2~4in,即51~114mm)铸钢件参考射线照相底片
E0192-04
Reference Radiographs of Investment Steel Castings for Aerospace Applications
宇航用熔模铸钢件参考射线照相底片
E0213-04
Practice for Ultrasonic Examination of Metal Pipe and Tubing
金属管材超声检测方法
E0214-01
Practice for Immersed Ultrasonic Examination by the Reflection Method Using Pulsed Longitudinal Waves
液浸式超声纵波脉冲反射检测方法
E0215-98R04E01
Practice for Standardizing Equipment for Electromagnetic Examination of Seamless Aluminum-Alloy Tube
无缝铝合金管电磁检测设备校准方法
E0242-01
Reference Radiographs for Appearances of Radiographic Images as Certain Parameters Are Changed
参数变更导致射线照相图像出现幻影的参考射线照相底片
E0243-97R04E01
Practice for Electromagnetic (Eddy-Current) Examination of Copper and Copper-Alloy Tubes
铜和铜合金管电磁(涡流)检测方法
E0272-99R04E01
Reference Radiographs for High-Strength Copper-Base and Nickel-Copper Alloy Castings
高强度铜基和镍铜合金铸件参考射线照相底片
E0273-01R05
Practice for Ultrasonic Examination of the Weld Zone of Welded Pipe and Tubing
焊制管焊接区超声检测方法
E0280-98R04E01
Reference Radiographs for Heavy-Walled (4 to 12-in. \[114 to 305-mm\]) Steel Castings
大厚度(4~12in,即114~305mm)铸钢件参考射线照相底片
E0309-95R01
Practice for Eddy-Current Examination of Steel Tubular Products Using Magnetic Saturation
钢管磁饱和涡流检测方法
E0310-99R04E01
Reference Radiographs for Tin Bronze Castings
青铜铸件参考射线照相底片
E0317-01
Practice for Evaluating Performance Characteristics of Ultrasonic Pulse-Echo Examination Instruments and Systems without the Use of Electronic Measurement Instruments
超声脉冲回波检测仪器和系统工作特性的非电子测量评定方法
E0376-03
Practice for Measuring Coating Thickness by Magnetic-Field or Eddy-Current (Electromagnetic) Examination Methods
覆盖层厚度的磁场或涡流(电磁)测量方法
E0390-01
Reference Radiographs for Steel Fusion Welds
钢熔焊焊缝参考射线照相底片
E0426-98R03E01
Practice for Electromagnetic (Eddy-Current) Examination of Seamless and Welded Tubular Products, Austenitic Stainless Steel and Similar Alloys
无缝和焊制管材、奥氏体不锈钢和类似合金管材电磁(涡流)检测方法
E0427-95R00
Practice for Testing for Leaks Using the Halogen Leak Detector (Alkali-Ion Diode)
(碱离子二极管)卤素检漏仪泄漏检测方法
E0428--05
Practice for Fabrication and Control of Steel Reference Blocks Used in Ultrasonic Examination
超声检测用钢参考试块的制作和控制方法
E0431-96R02
Guide to Interpretation of Radiographs of Semiconductors and Related Devices
半导体及其相关器件的射线照相底片解释指南
E0432-91R04
Guide for Selection of a Leak Testing Method
泄漏检测方法选择指南
E0433-71R03
Reference Photographs for Liquid Penetrant Inspection
渗透检测参考照片
E0446-98R04E01
Reference Radiographs for Steel Castings Up to 2 in. \[51 mm\] in Thickness
厚度在2in(51mm)以内的铸钢件参考射线照相底片
E0479-91R00
Guide for Preparation of a Leak Testing Specification
泄漏检测规范编写指南
E0493-97
Test Methods for Leaks Using the Mass Spectrometer Leak Detector in the Inside-Out Testing Mode
外泄式质谱检漏仪泄漏检测方法
E0494-95R01
Practice for Measuring Ultrasonic Velocity in Materials
材料超声速度测量方法
E0498-95R00
Test Methods for Leaks Using the Mass Spectrometer Leak Detector or Residual Gas Analyzer in the Tracer Probe Mode
示踪探头式残余气体分析仪或质谱检漏仪泄漏检测方法
E0499-95R00
Test Methods for Leaks Using the Mass Spectrometer Leak Detector in the Detector Probe Mode,
探头式质谱检漏仪泄漏检测方法
E0505-01
Reference Radiographs for Inspection of Aluminum and Magnesium Die Castings
铝和镁模铸件检测参考射线照相底片
E0515-95R00
Test Method for Leaks Using Bubble Emission Techniques
起泡散发技术泄漏检测方法
E0543-04
Practice for Agencies Performing Nondestructive Testing
机构执行无损检测的方法
E0545-05
Test Method for Determining Image Quality in Direct Thermal Neutron Radiographic Examination
直接热中子辐射照相检测的像质测定方法
E0566-99R04E01
Practice for Electromagnetic (Eddy-Current) Sorting of Ferrous Metals
铁金属电磁(涡流)分选方法
E0569-02
Practice for Acoustic Emission Monitoring of Structures During Controlled Stimulation
结构物在可控受激时声发射监测方法
E0570-97R04E01
Practice for Flux Leakage Examination of Ferromagnetic Steel Tubular Products
铁磁性钢管漏磁检测方法
E0571-98R03E01
Practice for Electromagnetic (Eddy-Current) Examination of Nickel and Nickel Alloy Tubular Products
镍和镍合金管材电磁(涡流)检测方法
E0587-00R05
Practice for Ultrasonic Angle-Beam Examination by the Contact Method
接触式超声斜射检测方法
E0592-99
Guide to Obtainable ASTM Equivalent Penetrameter Sensitivity for Radiography of Steel Plates to 2 in. (6 to 51 mm) Thick with X-Rays and 1 to 6 in. (25 to 152 mm) Thick with Cobalt-60
用X射线对0.25~2in(6~51mm)厚和用钴60对1~6in(25~152mm)厚钢板进行射线照相获得等效ASTM透度计灵敏度的指南
E0650-97R02E01
Guide for Mounting Piezoelectric Acoustic Emission Sensors
压电式声发射传感器安装指南
E0664-93R05
Practice for the Measurement of the Apparent Attenuation of Longitudinal Ultrasonic Waves by Immersion Method
液浸式超声纵波表观衰减测量方法
E0689-95R04E01
Reference Radiographs for Ductile Iron Castings
可锻铸铁参考射线照相底片
E0690-98R04E01
Practice for In Situ Electromagnetic (Eddy-Current) Examination of Nonmagnetic Heat Exchanger Tubes
非磁性热交换管现场电磁(涡流)检测方法
E0703-98R04E01
Practice for Electromagnetic (Eddy-Current) Sorting of Nonferrous Metals
非铁金属电磁(涡流)分选方法
E0709-01
Guide for Magnetic Particle Examination
磁粉检测指南
E0746-02
Test Method for Determining Relative Image Quality Response of Industrial Radiographic Film Systems
工业射线照相胶片相对像质响应的测定方法
E0747-04
Practice for Design, Manufacture and Material Grouping Classification of Wire Image Quality Indicators (IQI) Used for Radiology
射线线型像质计(IQI)的材料分类、设计和制作方法
E0748-02
Practices for Thermal Neutron Radiography of Materials
材料热中子辐射照相方法
E0749-01
Practice for Acoustic Emission Monitoring During Continuous Welding
焊接过程声发射监测方法
E0750-04
Practice for Characterizing Acoustic Emission Instrumentation
声发射仪性能表征方法
E0751-01
Practice for Acoustic Emission Monitoring During Resistance Spot-Welding
电阻点焊过程声发射监测方法
E0797-95R01
Practice for Measuring Thickness by Manual Ultrasonic Pulse-Echo Contact Method
接触式超声脉冲回波手工测厚方法
E0801-01
Practice for Controlling Quality of Radiological Examination of Electronic Devices
电子器件射线检测质量控制方法
E0802-95R05
Reference Radiographs for Gray Iron Castings Up to 4 in. (114 mm) in Thickness
厚度至4.5in(114mm)以内的灰铸铁参考射线照相底片
E0803-91R02
Test Method for Determining the L/D Ratio of Neutron Radiography Beams
中子辐射束L/D比的测定方法
E0908-98R04
Practice for Calibrating Gaseous Reference Leaks
参考泄漏气体校准方法
E0976-00
Guide for Determining the Reproducibility of Acoustic Emission Sensor Response
声发射传感器响应的再现性测定方法
E0977-05
Practice for Thermoelectric Sorting of Electrically Conductive Materials
导电材料温差电流分选方法
E0999-05
Guide for Controlling the Quality of Industrial Radiographic Film Processing
工业射线照相胶片处理过程质量控制指南
E1000-98R03
Guide for Radioscopy
射线透视指南
E1001-04
Practice for Detection and Evaluation of Discontinuities by the Immersed Pulse-Echo Ultrasonic Method Using Longitudinal Waves
液浸式超声纵波脉冲回波检测和评定不连续
E1002-05
Test Method for Leaks Using Ultrasonics
超声泄漏检测方法
E1003-95R00
Test Method for Hydrostatic Leak Testing
液压泄漏检测方法
E1004-02
Practice for Determining Electrical Conductivity Using the Electromagnetic (Eddy-Current) Method
电导率的电磁(涡流)测定方法
E1025-05
Practice for Design, Manufacture, and Material Grouping Classification of Hole-Type Image Quality Indicators (IQI) Used for Radiology
射线孔型像质计(IQI)的材料分类、设计和制作方法
E1030-00
Test Method for Radiographic Examination of Metallic Castings
金属铸件射线照相检测方法
E1032-01
Test Method for Radiographic Examination of Weldments
焊接件射线照相检测方法
E1033-98R04E01
Practice for Electromagnetic (Eddy-Current) Examination of Type F-Continuously Welded (CW) Ferromagnetic Pipe and Tubing Above the Curie Temperature
大于居里温度F型连续焊制(CW)的铁磁性管材电磁(涡流)检测方法
E1065-99R03
Guide for Evaluating Characteristics of Ultrasonic Search Units
超声探头特性评定指南
E1066-95R00
Test Method for Ammonia Colorimetric Leak Testing
氨比色泄漏检测方法
E1067-01
Practice for Acoustic Emission Examination of Fiberglass Reinforced Plastic Resin (FRP) Tanks/Vessels
玻璃纤维增强塑料树脂(FRP)储罐/容器声发射检测方法
E1079-05
Practice for Calibration of Transmission Densitometers
透射式密度计校准方法
E1106-86R02E01
Method for Primary Calibration of Acoustic Emission Sensors
声发射传感器一级校准方法
E1114-03
Test Method for Determining the Focal Size of Iridium-192 Industrial Radiographic Sources
铱192工业射线源焦点尺寸测定方法
E1118-05
Practice for Acoustic Emission Examination of Reinforced Thermosetting Resin Pipe (RTRP)
增强热固树脂管材(RTRP)声发射检测方法
E1135-97R03
Test Method for Comparing the Brightness of Fluorescent Penetrants
荧光渗透剂亮度比较方法
E1139-02
Practice for Continuous Monitoring of Acoustic Emission from Metal Pressure Boundaries
金属压力界线声发射连续监测方法
E1158-04
Guide for Material Selection and Fabrication of Reference Blocks for the Pulsed Longitudinal Wave Ultrasonic Examination of Metal and Metal Alloy Production Material
金属和金属合金产品材料超声脉冲纵波检测用参考试块的材料选择与制作指南
E1161-03
Test Method for Radiologic Examination of Semiconductors and Electronic Components
半导体和电子元件射线检测方法
E1165-04
Test Method for Measurement of Focal Spots of Industrial X-Ray Tubes by Pinhole Imaging
工业X射线管焦点针孔成像测定方法
E1208-05
Test Method for Fluorescent Liquid Penetrant Examination Using the Lipophilic Post-Emulsification Process
亲油性后乳化型荧光渗透检测方法
E1209-05
Test Method for Fluorescent Liquid Penetrant Examination Using the Water-Washable Process
水洗型荧光渗透检测方法
E1210-05
Test Method for Fluorescent Liquid Penetrant Examination Using the Hydrophilic Post-Emulsification Process
亲水性后乳化型荧光渗透检测方法
E1211-02
Practice for Leak Detection and Location Using Surface-Mounted Acoustic Emission Sensors
声发射传感器表面安装的检漏和定位方法
E1212-04
Practice for Quality Management Systems for Nondestructive Testing Agencies
无损检测机构质量保证体系实施方法
E1213-97R02
Test Method for Minimum Resolvable Temperature Difference for Thermal Imaging Systems
热成像系统最小可分辨温差检测方法
E1219-05
Test Method for Fluorescent Liquid Penetrant Examination Using the Solvent-Removable Process
溶剂去除型荧光渗透检测方法
E1220-05
Test Method for Visible Penetrant Examination Using Solvent-Removable Process
溶剂去除型着色渗透检测方法
E1254-03
Guide for Storage of Radiographs and Unexposed Industrial Radiographic Films
射线照相底片和未曝光工业射线照相胶片贮存指南
E1255-96R02
Practice for Radioscopy
射线透视方法
E1311-89R04
Test Method for Minimum Detectable Temperature Difference for Thermal Imaging Systems
热成像系统最小可探测温差检测方法
E1312-99R04E01
Practice for Electromagnetic (Eddy-Current) Examination of Ferromagnetic Cylindrical Bar Product Above the Curie Temperature
大于居里温度的铁磁性圆棒材电磁(涡流)检测方法
E1315-93R02
Practice for Ultrasonic Examination of Steel with Convex Cylindrically Curved Entry Surfaces
圆钢棒凸面的超声检测方法
E1316-05
Terminology for Nondestructive Testing
无损检测术语
E1320-05
Reference Radiographs for Titanium Castings
钛铸件参考射线照相底片
E1324-00R05
Guide for Measuring Some Electronic Characteristics of Ultrasonic Examination Instruments
超声检测仪电特性测量指南
E1359-02
Guide for Evaluating Capabilities of Nondestructive Testing Agencies
无损检测机构能力评定指南
E1390-90R00
Guide for Illuminators Used for Viewing Industrial Radiographs
工业射线照相底片观片灯指南
E1411-01
Practice for Qualification of Radioscopic Systems
射线透视系统质量鉴定方法
E1416-04
Test Method for Radioscopic Examination of Weldments
焊接件射线透视检测方法
E1417-05
Practice for Liquid Penetrant Testing
渗透检测操作方法
E1418-05
Test Method for Visible Penetrant Examination Using the Water-Washable Process
水洗型着色渗透检测方法
E1419-02B
Test Method for Examination of Seamless, Gas-Filled, Pressure Vessels Using Acoustic Emission
无缝、充气的压力容器声发射检测方法
E1441-00
Guide for Computed Tomography (CT) Imaging
计算机层析成像(CT)指南
E1444-05
Practice for Magnetic Particle Testing
磁粉检测方法
E1453-93R02E01
Guide for Storage of Media that Contains Analog or Digital Radioscopic Data
模拟或数字化射线透视数据储存介质贮存指南
E1454-02
Guide for Data Fields for Computerized Transfer of Digital Ultrasonic Examination Data
数字化超声检测数据的计算机转换数据段指南
E1475-02
Guide for Data Fields for Computerized Transfer of Digital Radiological Examination Data
数字化射线检测数据的计算机转换数据段指南
E1476-04
Guide for Metals Identification, Grade Verification, and Sorting
金属牌号、等级验证与分选指南
E1495-02
Guide for Acousto-Ultrasonic Assessment of Composites, Laminates, and Bonded Joints
复合、层压和粘结接头的声-超声评定指南
E1496-05
Test Method for Neutron Radiographic Dimensional Measurements
中子辐射照相尺度测量方法
E1543-00
Test Method for Noise Equivalent Temperature Difference of Thermal Imaging Systems
热成像系统噪声当量温差检测方法
E1570-00
Practice for Computed Tomographic (CT) Examination
计算机层析成像(CT)检测方法
E1571-01
Practice for Electromagnetic Examination of Ferromagnetic Steel Wire Rope
铁磁性钢丝绳电磁检测方法
E1603-99
Test Methods for Leakage Measurement Using the Mass Spectrometer Leak Detector or Residual Gas Analyzer in the Hood Mode
罩式残余气体分析仪或质谱检漏仪泄漏测量方法
E1606-99R04E01
Practice for Electromagnetic (Eddy-Current) Examination of Copper Redraw Rod for Electrical Purposes
电工用二次拉制铜棒电磁(涡流)检测方法
E1629-94R01
Practice for Determining the Impedance of Absolute Eddy-Current Probes
绝对式涡流探头阻抗测定方法
E1647-03
Practice for Determining Contrast Sensitivity in Radiology
射线法中反差灵敏度测定方法
E1648-95R01
Reference Radiographs for Examination of Aluminum Fusion Welds
铝熔焊焊缝检测参考射线照相底片
E1672-95R01E01
Guide for Computed Tomography (CT) System Selection
计算机层析成像(CT)系统选择指南
E1695-95R01
Test Method for Measurement of Computed Tomography (CT) System Performance
计算机层析成像(CT)系统性能测试方法
E1734-04
Practice for Radioscopic Examination of Castings
铸件射线透视检测方法
E1735-95R00E01
Test Method for Determining Relative Image Quality of Industrial Radiographic Film Exposed to X-Radiation from 4 to 25 MV
4至25MV X射线曝光后的工业射线照相胶片相对像质测试方法
E1736-05
Practice for Acousto-Ultrasonic Assessment of Filament-Wound Pressure Vessels
卷绕层压力容器声-超声评定方法
E1742-05
Practice for Radiographic Examination
射线照相检测方法
E1774-96R02
Guide for Electromagnetic Acoustic Transducers (EMATs)
电磁声换能器(EMATs)指南
E1781-98R03E01
Practice for Secondary Calibration of Acoustic Emission Sensors
声发射传感器二级校准方法
E1814-96R02
Practice for Computed Tomographic (CT) Examination of Castings
铸件计算机层析成像(CT)检测方法
E1815-96R01
Test Method for Classification of Film Systems for Industrial Radiography
工业射线照相胶片系统分类方法
E1816-96R02
Practice for Ultrasonic Examinations Using Electromagnetic Acoustic Transducer (EMAT) Techniques
电磁声换能器(EMAT)技术超声检测方法
E1817-03
Practice for Controlling Quality of Radiological Examination by Using Representative Quality Indicators (RQIs)
用代表性像质计(RQIs)控制射线检测质量的方法
E1862-97R02E01
Test Methods for Measuring and Compensating for Reflected Temperature Using Infrared Imaging Radiometers
反射温度用红外成像辐射计测量和补偿测试方法
E1888_E1888M-02
Test Method for Acoustic Emission Examination of Pressurized Containers Made of Fiberglass Reinforced Plastic with Balsa Wood Cores
Balsa
用香脂木芯结构玻璃纤维增强塑料制造的加压容器声发射检测方法
E1897-97R02E01
Test Methods for Measuring and Compensating for Transmittance of an Attenuating Medium Using Infrared Imaging Radiometers
衰减介质穿透用红外成像辐射计测量和补偿测试方法
E1901-97R03
Guide for Detection and Evaluation of Discontinuities by Contact Pulse-Echo Straight-Beam Ultrasonic Methods
接触式超声脉冲回波直射检测和评定不连续
E1930-02
Test Method for Examination of Liquid-Filled Atmospheric and Low-Pressure Metal Storage Tanks Using Acoustic Emission
充液的常压和低压金属储罐声发射检测方法
E1931-97R03
Guide for X-Ray Compton Scatter Tomography
X射线康普顿散射层析成像指南
E1932-97R02E01
Guide for Acoustic Emission Examination of Small Parts
小型部件声发射检测指南
E1933-99AR05E01
Test Methods for Measuring and Compensating for Emissivity Using Infrared Imaging Radiometers
辐射率用红外成像辐射计测量和补偿测试方法
E1934-99AR05E01
Guide for Examining Electrical and Mechanical Equipment with Infrared Thermography
电气和机械设备红外热成像检测指南
E1935-97R03
Test Method for Calibrating and Measuring CT Density
CT密度测量和校准方法
E1936-03
Reference Radiograph for Evaluating the Performance of Radiographic Digitization Systems
评定射线照相数字系统性能的参考射线照相底片
E1955-04
Radiographic Examination for Soundness of Welds in Steel by Comparison to Graded ASTM E 390 Reference Radiographs
与 ASTM E390 分级参考射线照相底片作比较评定钢焊缝完整性的射线照相检测
E1961-98R03E01
Practice for Mechanized Ultrasonic Examination of Girth Welds Using Zonal Discrimination with Focused Search Units
用聚焦探头焦柱的环焊缝自动超声检测方法
E1962-04
Test Method for Ultrasonic Surface Examinations Using Electromagnetic Acoustic Transducer (EMAT) Techniques
电磁声换能器(EMAT)技术超声表面检测方法
E2001-98R03
Guide for Resonant Ultrasound Spectroscopy for Defect Detection in Both Metallic and Non-metallic Parts
金属与非金属部件缺陷探测的共振超声波谱法指南
E2002-98R03E01
Practice for Determining Total Image Unsharpness in Radiology
放射学中图像总不清晰度测定方法
E2003-98R04
Practice for Fabrication of the Neutron Radiographic Beam Purity Indicators
中子辐射束纯度计制作方法
E2007-00
Guide for Computed Radiology (Photostimulable Luminescence (PSL) Method)
计算机放射学(光激发光法,PSL)指南
E2023-99R04
Practice for Fabrication of Neutron Radiographic Sensitivity Indicators
中子辐射照相灵敏度计制作方法
E2024-99
Test Methods for Atmospheric Leaks Using a Thermal Conductivity Leak Detector
热导率检漏仪常压泄漏检测方法
E2033-99
Practice for Computed Radiology (Photostimulable Luminescence Method)
计算机放射学(光激发光法)方法
E2075-05
Practice for Verifying the Consistency of AE-Sensor Response Using an Acrylic Rod
AE传感器响应一致性的丙烯酸棒验证方法
E2076-05
Test Method for Examination of Fiberglass Reinforced Plastic Fan Blades Using Acoustic Emission
玻璃纤维增强塑料叶片声发射检测方法
E2096-05
Practice for In Situ Examination of Ferromagnetic Heat-Exchanger Tubes Using Remote Field Testing
铁磁性热交换管远场检测的现场检测方法
E2104-01
Practice for Radiographic Examination of Advanced Aero and Turbine Materials and Components
飞机和涡轮机材料和部件射线照相检测方法
E2191-02
Test Method for Examination of Gas-Filled Filament-Wound Composite Pressure Vessels Using Acoustic Emission
卷绕复合层充气压力容器声发射检测方法
E2192-02
Guide for Planar Flaw Height Sizing by Ultrasonics
平面型伤高度超声定量指南
E2223-02
Practice for Examination of Seamless, Gas-Filled, Steel Pressure Vessels Using Angle Beam Ultrasonics
无缝、充气的钢压力容器超声斜射检测方法
E2261-03
Practice for Examination of Welds Using the Alternating Current Field Measurement Technique
交流电场测量技术的焊缝检测方法
E2297-04
Guide for Use of UV-A and Visible Light Sources and Meters used in the Liquid Penetrant and Magnetic Particle Methods
液体渗透和磁粉方法用UV-A和可见光源及强度计的使用指南
E2337-04
Guide for Mutual Inductance Bridge Applications for Wall Thickness Determinations in Boiler Tubing
锅炉管壁的互感电桥测厚指南
E2338-04
Practice for Characterization of Coatings Using Conformable Eddy-Current Sensors without Coating Reference Standards
不带参考覆盖层的类似涡流传感器的覆盖层表征方法
E2339-04
Practice for Digital Imaging and Communication in Nondestructive Evaluation (DICONDE)
无损检测中的数字图像与传输(DICONDE)方法
E2374-04
Guide for Acoustic Emission System Performance Verification
声发射系统性能验证指南
E2445-05
Practice for Qualification and Long-Term Stability of Computed Radiology Systems
计算机射线照相系统的长期稳定性与鉴定方法
E2446-05
Practice for Classification of Computed Radiology Systems
计算机射线照相系统的分类方法
fgh222 | 2016-1-22 21:49:01 | 显示全部楼层
看看了
fgh222 | 2016-1-24 00:52:19 | 显示全部楼层
看看了
