[讨论] 声发射相关论文,探头安装实例图片、信号实例
查看13827 | 回复2 | 2013-1-5 11:51:07 | 显示全部楼层 |阅读模式
128   0 00:00:00.0000000         Acquisition Running
ID DDD HH:MM:SS.mmmuuun      PARA1  CH  RISE  COUN  ENER  DURATION AMP
  1   0 00:00:36.7095215    -0.0037   1    54  1920  3699     21145  95
  1   0 00:00:36.7095290    -0.0037   3   356  4143  9532     45723  97
  1   0 00:00:36.7095320    -0.0037   2   414  1885  3199     21260  92
* Gp# 1[1,3,2] x =    709.5, y =    619.4 dT[     7,    10] Src Amplitude = 95.0
*     0 00:00:36.7095215    -0.0037   1    54  1920  3699     21145  95
*     0 00:00:36.7095290    -0.0037   3   356  4143  9532     45723  97
*     0 00:00:36.7095320    -0.0037   2   414  1885  3199     21260  92
  1   0 00:02:58.5564825    -0.0024   1     1     2     0         4  44
  1   0 00:03:31.6597205    -0.0003   1   253     9     2       451  42
  1   0 00:03:35.1094187    -0.0018   1   191    47     5       650  48
  1   0 00:03:39.4023077    -0.0009   1     2     2     0         9  45
  1   0 00:03:39.4419760    -0.0027   1     2     3     0        10  47
  1   0 00:03:39.4820147    -0.0067   1     2     3     0        11  47
  1   0 00:03:39.5220895    -0.0031   1     2     4     0        17  47
  1   0 00:03:39.5626390    -0.0015   1     2     2     0         9  44
  1   0 00:03:39.7582560    -0.0037   1    13    43     5       733  45
  1   0 00:03:54.3399947    -0.0006   1   362   142    12      1030  47
  1   0 00:03:57.3084017    -0.0003   1    10     4     0        40  42
  1   0 00:04:00.5056237    -0.0003   1   191   137    13      1113  50
  1   0 00:04:39.8939677     0.0009   1     4     5     0        25  50
  1   0 00:04:39.9168007    -0.0024   1     0     2     0         9  46
  1   0 00:04:39.9566887    -0.0018   1     4     3     0        11  46
  1   0 00:04:39.9966987    -0.0034   1     4     4     0        19  46
  1   0 00:04:40.0367645    -0.0009   1     1     3     0        11  46
  1   0 00:04:40.0768815    -0.0006   1     1     3     0         9  46
  1   0 00:04:40.1170355    -0.0027   1     1     2     0         8  44
  1   0 00:04:40.1572327    -0.0003   1     2     2     0         9  43
  1   0 00:04:40.1974860    -0.0034   1     2     1     0         2  41
  1   0 00:04:49.2026020    -0.0024   1     2     1     0         2  40
  1   0 00:04:49.2292020    -0.0021   1     2     4     0        28  48
  1   0 00:04:49.2623947    -0.0037   1     2     1     0        28  40
  1   0 00:04:49.2888257    -0.0024   1     4     5     0        28  48
  1   0 00:04:49.3219987    -0.0006   1     4     1     0        28  40
  1   0 00:04:49.3484760    -0.0027   1     2     4     0        20  49
  1   0 00:04:49.3816165    -0.0015   1     2     1     0        20  40
  1   0 00:04:49.4080300    -0.0040   1     2     4     0        20  50
  1   0 00:04:49.4411875    -0.0027   1     2     1     0         7  42
  1   0 00:04:49.4676930    -0.0021   1     2     4     0        21  49
  1   0 00:04:49.5009290    -0.0024   1     2     2     0        13  41
  1   0 00:04:49.5274320    -0.0027   1     2     4     0        21  50
  1   0 00:04:49.5606480    -0.0012   1     2     2     0        13  41
  1   0 00:04:49.5872027    -0.0021   1     2     5     0        22  49
  1   0 00:04:49.6204870    -0.0015   1     7     2     0        13  41
  1   0 00:04:49.6470470    -0.0052   1     2     4     0        21  51
  1   0 00:04:49.6803505    -0.0052   1    12     2     0        29  41
  1   0 00:04:49.7069700    -0.0018   1     2     4     0        21  49
  1   0 00:04:49.7402815    -0.0006   1    29     2     0        29  41
  1   0 00:04:49.7669307    -0.0012   1     2     5     0        22  50
  1   0 00:04:49.8003210    -0.0027   1     2     2     0         8  41
  1   0 00:04:49.8269470    -0.0061   1     2     5     0        23  50
  1   0 00:04:49.8603327    -0.0024   1    12     2     0        12  41
  1   0 00:04:49.8869617    -0.0012   1     1     5     0        22  49
  1   0 00:04:49.9203350    -0.0027   1     1     2     0        29  41
  1   0 00:04:49.9469780    -0.0027   1     2     5     0        23  50
  1   0 00:04:49.9803187    -0.0015   1    12     2     0        29  41
  1   0 00:04:50.0069560    -0.0027   1     2     5     0        23  49
  1   0 00:04:50.0402905    -0.0034   1     2     3     0        29  41
  1   0 00:04:50.0669215    -0.0034   1     2     5     0        22  50
  1   0 00:04:50.1002495    -0.0027   1     2     3     0        29  43
  1   0 00:04:50.1268800    -0.0034   1     2     5     0        21  49
  1   0 00:04:50.1602137    -0.0015   1     0     2     0        12  41
  1   0 00:04:50.1868350    -0.0015   1     2     4     0        21  49
  1   0 00:04:50.2201727    -0.0018   1    12     1     0        12  40
  1   0 00:04:50.2467790    -0.0021   1     2     5     0        23  49
  1   0 00:04:50.2801527    -0.0034   1     0     3     0        29  42
  1   0 00:04:50.3067557    -0.0027   1     1     5     0        22  49
  1   0 00:04:50.3401390    -0.0003   1     1     2     0         3  42
  1   0 00:04:50.3667457    -0.0024   1     2     4     0        20  49
  1   0 00:04:50.4000865    -0.0015   1     7     2     0        12  42
  1   0 00:04:50.4267430    -0.0027   1     2     4     0        21  50
  1   0 00:04:50.4600757    -0.0006   1     0     2     0        12  41
  1   0 00:04:50.4867005    -0.0052   1     1     4     0        20  49
  1   0 00:04:50.5200657    -0.0024   1     0     1     0         0  41
  1   0 00:04:50.5466660    -0.0031   1     2     5     0        23  49
  1   0 00:04:50.5799897    -0.0018   1     0     2     0         3  42
  1   0 00:04:50.6066450    -0.0034   1     2     5     0        20  49
  1   0 00:04:50.6399700    -0.0034   1     2     2     0         0  41
  1   0 00:04:50.6665745    -0.0034   1     1     5     0        22  49
  1   0 00:04:50.6999450    -0.0024   1     1     1     0         0  41
  1   0 00:04:50.7265927    -0.0015   1     2     5     0        23  50
  1   0 00:04:50.7599285    -0.0027   1     2     2     0        12  43
  1   0 00:04:50.7865545    -0.0018   1     1     5     0        22  49
  1   0 00:04:50.8199300    -0.0034   1     1     1     0         3  42
  1   0 00:04:50.8465820    -0.0018   1     2     5     0        32  49
  1   0 00:04:50.8799315    -0.0015   1     2     2     0        29  43
  1   0 00:04:50.9065487    -0.0034   1     2     5     0        23  49
  1   0 00:04:50.9399080     0.0003   1     2     1     0         0  41
  1   0 00:04:50.9665397    -0.0027   1     2     4     0        20  49
  1   0 00:04:50.9999367    -0.0027   1     0     1     0         0  41
  1   0 00:04:51.0265690    -0.0006   1     2     5     0        28  49
  1   0 00:04:51.0599147    -0.0015   1     0     2     0        29  42
  1   0 00:04:51.0865725    -0.0070   1     2     5     0        28  50
  1   0 00:04:51.1199637    -0.0018   1     0     1     0         0  41
  1   0 00:04:51.1466235    -0.0027   1     2     4     0        20  49
  1   0 00:04:51.1800237    -0.0046   1     0     2     0         0  41
  1   0 00:04:51.2066995    -0.0015   1     1     5     0        22  49
  1   0 00:04:51.2401595    -0.0052   1     1     1     0        22  40
  1   0 00:04:51.2668340    -0.0040   1     2     4     0        20  49
  1   0 00:04:51.3002437    -0.0037   1     2     1     0        20  40
  1   0 00:04:51.3268707    -0.0018   1     2     4     0        20  48
  1   0 00:04:51.3602120    -0.0015   1     2     1     0         0  40
  1   0 00:04:51.3868157    -0.0021   1     2     4     0        17  49
  1   0 00:04:51.4201155    -0.0021   1     2     1     0        17  40
  1   0 00:04:51.4466720    -0.0018   1     2     4     0        20  49
  1   0 00:04:51.4798850    -0.0040   1     2     1     0         0  40
  1   0 00:04:51.5063580    -0.0052   1     2     4     0        20  49
  1   0 00:04:51.5392560    -0.0018   1     2     2     0        12  41
  1   0 00:04:51.5660887    -0.0012   1     2     5     0        20  49
  1   0 00:04:51.5995680    -0.0006   1     2     1     0         3  41
  1   0 00:04:51.6262127    -0.0024   1     2     4     0        20  49
  1   0 00:04:51.6595610    -0.0021   1     2     2     0         3  43
  1   0 00:04:51.6861760    -0.0015   1     2     4     0        20  49
  1   0 00:04:51.7195137    -0.0024   1     0     2     0        12  42
  1   0 00:04:51.7461257    -0.0040   1     2     4     0        20  49
  1   0 00:04:51.7794635    -0.0027   1     2     1     0         2  41
  1   0 00:04:51.8060767    -0.0021   1     2     4     0        20  49
  1   0 00:04:51.8394140    -0.0012   1    12     1     0        12  41
  1   0 00:04:51.8660275    -0.0021   1     1     4     0        20  49
  1   0 00:04:51.8993650    -0.0040   1     3     1     0         3  40
  1   0 00:04:51.9259785    -0.0015   1     1     5     0        22  50
  1   0 00:04:51.9593167    -0.0052   1     0     2     0        12  41
  1   0 00:04:51.9859310    -0.0003   1     2     5     0        20  49
  1   0 00:04:52.0192700    -0.0018   1     2     2     0         3  41
  1   0 00:04:52.0458837    -0.0034   1     2     4     0        20  49
  1   0 00:04:54.0568785    -0.0012   1    27     4     2      1005  41
  1   0 00:04:54.3268595    -0.0015   1   494    47     6       794  47
  1   0 00:04:54.8964640    -0.0061   1   619    44     6       808  50
  1   0 00:06:03.0173255    -0.0015   1    26     6     4      1067  42
  1   0 00:06:06.4600137    -0.0018   1  1007   170    15      1266  47
  1   0 00:06:10.7560615    -0.0021   1  1007     3     0         9  46
  1   0 00:06:10.7890920    -0.0015   1  1007     1     0         0  40
  1   0 00:06:10.8157555    -0.0031   1  1007     4     0        17  47
  1   0 00:06:10.8558047    -0.0067   1     1     4     0        19  47
  1   0 00:06:10.8963440    -0.0015   1     1     2     0         9  45
  1   0 00:06:10.9369655    -0.0015   1     1     2     0         1  40
  1   0 00:06:11.1234475    -0.0046   1    66    91     9      1092  45
  1   0 00:06:25.6380087    -0.0037   1     2    84     8      1062  45
  1   0 00:06:28.6054205    -0.0058   1   377     5     1       377  42
  1   0 00:06:31.8183787    -0.0024   1   280    94    10      1087  46
  1   0 00:06:41.5663207    -0.0034   1     2     4     0       120  42
  1   0 00:06:41.7085710    -0.0034   1     3     2     0         8  44
  1   0 00:06:41.7442257    -0.0003   3    43     2     0        47  42
  1   0 00:06:41.7457097    -0.0015   1   393     7     3       932  48
  1   0 00:06:41.7698305    -0.0037   1     7    14     2       208  53
  1   0 00:06:41.7929327    -0.0015   1   153     9     1       157  44
  1   0 00:06:41.8160520    -0.0052   1    35     6     0        73  44
  1   0 00:06:41.8923635    -0.0058   1    16     8     1        83  48
  1   0 00:06:41.9886385    -0.0040   1    33    12     1       136  49
  1   0 00:06:42.0375980    -0.0024   1     8    22     3       252  51
  1   0 00:06:42.0630567    -0.0015   1    44     4     0        49  44
  1   0 00:06:42.0876930    -0.0015   1    28     3     0        31  42
  1   0 00:06:42.1161850    -0.0018   1    50     2     0        50  40
  1   0 00:06:42.1648107    -0.0015   1    13    20     3       194  53
  1   0 00:06:42.2219195    -0.0012   1   140    10     3       798  47
  1   0 00:06:42.2452030    -0.0021   1  4698    15    22      6606  45
  1   0 00:06:42.2757775    -0.0003   1   835    17     9      2658  49
  1   0 00:06:42.3010885    -0.0034   1   835     1     2      2658  40
  1   0 00:06:42.5704900    -0.0027   1   119    13     2       218  47
  1   0 00:06:42.6912040    -0.0055   1     4     2     0        10  48
  1   0 00:06:42.6914650    -0.0018   3    16     3     0        16  41
  1   0 00:06:53.9999637    -0.0027   1     4     4     0        14  50
  1   0 00:06:54.0261370    -0.0015   1     4     2     0         9  46
  1   0 00:06:54.0658367    -0.0018   1     4     3     0        11  47
  1   0 00:06:54.1058515    -0.0055   1     2     4     0        17  46
  1   0 00:06:54.1459217    -0.0012   1     4     4     0        28  46
  1   0 00:06:54.1860380    -0.0009   1     2     3     0        11  46
  1   0 00:06:54.2262177    -0.0018   1     0     2     0         9  45
  1   0 00:06:54.2664227    -0.0018   1     2     2     0         9  43
  1   0 00:06:54.3066870    -0.0018   1     2     1     0         2  42
15 407 05:26:12.0888317          Acquisition Aborted
barbaria | 2013-1-5 11:53:32 | 显示全部楼层
声发射文章
barbaria | 2013-1-5 12:02:16 | 显示全部楼层
barbaria 发表于 2013-1-5 11:53
声发射文章
1、检测过程中的部分数据
ID DDD HH:MM:SS.mmmuuun      PARA1      CH  RISE    COUN  ENER  DURATION   AMP新图片
图一检测过程中的部分数据
2、摩擦模拟信号的部分数据
采自信号线与钢板之间的摩擦
ID DDD HH:MM:SS.mmmuuun      PARA1      CH  RISE    COUN  ENER  DURATION   AMP新图片(1)
图二摩擦模拟信号的部分数据
3、电子噪声信号
探头产生的噪声信号
ID DDD HH:MM:SS.mmmuuun      PARA1      CH    RISE    COUN  ENER  DURATION   AMP  新图片(2)
图三电子噪声信号
图一中13通道中的信号与图二中的信号相似,图一中4通道中的信号与图三中的信号相似。
通过以上数据的对比分析可以看出,在检测过程中存在着大量的摩擦信号。分析产生的原因可能是以下几点:
1、结构的摩擦,脚手架、容器的支座、裙座、柱腿和平台等焊接垫板所引起,产生的声发射定位源散布在较大的范围,而且不满足Kaiser效应,即在降压后的第二次升压过程中仍产生大量的声发射信号。
2、检测过程中信号线未有效的固定,检测过程中有风存在导致信号线与容器本体产生摩擦。大风可吹动脚手架上的砂子或移动的物体撞击容器的外壳,风吹动引起的声发射定位源信号散布在容器迎风面的区域。
3、电子噪声,根据大量压力容器现场检验的经验发现,采集到的几乎所有的电子噪声信号不是来自外部环境,而是来自声发射仪器系统的内部。声发射系统内部的电子噪声源主要包括探头、信号线、前置放大器、电缆线及信号采集板等。
下次检测中应注意的问题:
1、避免在大风天进行检测,固定好信号线,避免摩擦。
2、排除结构的摩擦,特别是脚手架、容器的支座等。
3、电子噪声由于来自不同通道的电子信号是互不相关的,所以不会形成稳定的声发射定位源。所以一般不必考虑。
4、检测前背景噪声的测量中不应存在干扰信号。
5、摩擦信号与电子噪声形成声发射事件无法在实际的容器上定位。
参考文献
1、沈功田等,无损检测,《现场压力容器检验的声发射源》,第21卷第7期321~325,1999年7月
{:soso_e181:}
