[讨论] 棒材涡流阵列相控阵超声(或常规超声)联合检测系统
查看15016 | 回复7 | 2012-6-19 16:52:04 | 显示全部楼层 |阅读模式
ECA and PA (or conventional UT) Bar Inspection System
应用:棒材涡流阵列相控阵超声(或常规超声)检测系统检测棒材内部和表面缺陷。
Application: ECA and PA (or conventional UT) Bar Inspection System detects Inner and surface defects.
特大规格圆棒涡流阵列相控阵超声(或常规超声)联合检测系统
ECA and PA (or conventional UT) large diameter round Bar Inspection System
应用:特大规格圆棒涡流阵列相控阵超声(或常规超声)检测系统检测棒材内部和表面缺陷。
Application: ECA and PA (or conventional UT) large diameter round Bar Inspection System detects Inner and surface defects.
远东网 | 2012-6-20 17:45:23 | 显示全部楼层
szy | 2012-6-20 20:03:31 | 显示全部楼层
丁伟臣 | 2012-6-29 19:47:59 | 显示全部楼层
czl343608193 | 2012-12-6 10:30:26 | 显示全部楼层
<img src=&quot;static/image/smiley/comcom/1.gif&quot; class=&quot;vm&quot;>
汪冬兵 | 2013-5-16 08:18:25 | 显示全部楼层
allen_hay | 2013-5-16 09:13:54 | 显示全部楼层
这个讨论帖我们要讨论些什么呢?
还是觉得是个广告帖……
飞马踏燕 | 2013-7-7 08:28:15 | 显示全部楼层
{:soso_e132:}{:soso_e132:}{:soso_e101:}
